Redfish_fisherman
Thread starter- Joined
- Jun 8, 2015
- 25
I have a 1995 150 hp Johnson Outboard motor (Model # J150ELEOM) that continues to over heat only wen it reaches 3900 RPMS 35 Miles per hour. The max speed for the engine is 56 MPH. The motor does not over heat if it doesn't go over the 3900 RPM range and when it gets to 3900 it don't overheat ASAP it usualy takes 2-3 minutes for it to. Things down to the motor are: New Spark Plugs, New Water Impeller, New Fuel Pump (Non-VRO), New fuel water separator, all new fuel lines going from the tank to the motor, New fuel bulb, New Fuel Filter, New Vapor Separator, New Vapor Pump, New starter, and New Thermostats. The enigine after all of this is still over heating. the Compression I know is really low which is 60, 60 62, 65, 64, 63 on all the cylinders, but there is NOT a present knocking in the enogine so I know that isn't a problem with the over heating issue. Also I have been told this engine does not have water deflectors for the year and model of the boat. I am totally lost with this and have been experiencing this isse since last June and would like to resolve the issue finally.
