1995 150 hp Johnson Overheating Issue
Redfish_fisherman
I have a 1995 150 hp Johnson Outboard motor (Model # J150ELEOM) that continues to over heat only wen it reaches 3900 RPMS 35 Miles per hour. The max speed for the engine is 56 MPH. The motor does not over heat if it doesn't go over the 3900 RPM range and when it gets to 3900 it don't overheat ASAP it usualy takes 2-3 minutes for it to. Things down to the motor are: New Spark Plugs, New Water Impeller, New Fuel Pump (Non-VRO), New fuel water separator, all new fuel lines going from the tank to the motor, New fuel bulb, New Fuel Filter, New Vapor Separator, New Vapor Pump, New starter, and New Thermostats. The enigine after all of this is still over heating. the Compression I know is really low which is 60, 60 62, 65, 64, 63 on all the cylinders, but there is NOT a present knocking in the enogine so I know that isn't a problem with the over heating issue. Also I have been told this engine does not have water deflectors for the year and model of the boat. I am totally lost with this and have been experiencing this isse since last June and would like to resolve the issue finally.
fhhuber
New issue on an engine that has been fine before?
did you change the prop or put the engine on a different boat?
Excess load can cause it.
Blowby going into the crankcase may be leaning the mix and causing it too...
reiddo1
I am really puzzled how a 150 hp engine with only 60 psi on each cylinder can deliver a boat speed of 56 mph. My 2000 150 hp Johnson Oceanpro with 105 psi compression minimum pushes my Glastron Sea Fury v216 at 37 mph according to my GPS. You must have this engine mounted on a really small boat and I am wondering whether you have a higher mounted engine where the boat is rising in the water above 3900 rpm and not getting adequate water to the water pump.
The picture you have painted needs more clarity.
Redfish_fisherman
This is the same original motor for the boat and prop as well. Have had this boat for only 1.5 years and now just recently started having this problem
Redfish_fisherman
This is the original motor for the boat and the boat is rated for a 150. God says when the boat was working properly I was going 56 wot
bob johnson
I don't know exactly how to progressively address your issue , but I would at least remove the t stats and give it a run and make note of the results...that will provide some more info... do you have a water pressure guage?.... it is possible your compression gauge is off.... are all the plugs out when you take readings??
what do the plugs look like? for curiousity sake, what is the max rpm when you hit 56?????
bob
Redfish_fisherman
bob
Yes all the plugs were out and I turned the engine over each time per cylinder for 5-8 seconds to check the compression. Also the thermostats are brand new replaced both of them and I was going to run it without them but a mechanic of 30 years who been working on Johnson and evinrude motors says it can damage the engine for running it like that. And the plugs are brand new and the required champion plugs for it
fhhuber
I can believe the 56 mph... with a relatively light hull and the right prop. And the engine running right (but 60 psi per cyl won't run right)
I haven't GPS'd my current hull and prop (with new lower end) but with a heavier hull and kind of rough edged prop and sad gears in the lower end, I was hitting 50 by GPS with my 1989 (mfg date) Johnson 150 GT
Redfish_fisherman
My boat is a 1991 17 ft center console sea pro
Brock O
bob johnson
Hi Guys
Link below shared to me by other on this site concerning my 95 Johno, may be way of track but though id share as things only get worse, don't push the alarm that's for sure.
http://forums.iboats.com/forum/engi...aq/228380-johnson-evinrude-adding-a-tell-tale
The water deserter's in the jacket go to **** over time restricting the correct water flow also which could be contributing.
http://forums.iboats.com/forum/engi...nson-evinrude-outboards/9145634-0-compression
Regards
Brock
not the same motor completely different design!!!!!!!!
BOB
oldboat1
Should measure temps apart from installed gauges or systems, if you haven't already -- might try a temp sensor to get some numbers.
tommarvin
Ensign
Overheating is three things, water pump/impeller, thermostat put in a pan of water heat it up slowly,what temp does it open, lastly the overheat sensor, take it out and test it, put the end in hot water an IR thermometer helps here to check water temp, was it a faulty sensor and it never overheated?
James R
Three points. what changed last June that may cause this problem. Was the prop changed, was the boat weight distribution changed, any other changes that may cause cavitation at the higher RPM. The compression's in my opinion are way below what would be needed to achieve the stated performance. Your gauge may be defective. Is this in fact overheat or a different problem.
clanton
How do you know the engine is over heating? Temp alarm, laser temp checker, wax crayon, finger check, brown colored paint on cylinder head? There is an o-ring between the impellor cup and the plastic waterpump housing, this o-ring bad causes high speed over heat.
