1995 120HP Force Lower Unit Removal
forceguy
Hey guys, I'm about to change the impeller on my 1995 Force 120HP motor, but I'm not sure if I need to do anything with the shift linkage before removing the bolts. If I do need to unhook the linkage, where do I get access, and do I unhook it? The Seloc manual is very confusing as isn't any help with this one.
Your help is very much appreciated.
Thanks.
Jiggz
Re: 1995 120HP Force Lower Unit Removal
There is a sticky post on the top of this forum. It will give you a detailed step by step procedure on how to replace the water impeller.
