1994 Yami ProV 150, pulls hard to the right
Olin83
My ProV 150 seems to have a hard right hand pull. Any suggestions? Also the steering wheel is not centered to the motor. Is ther an easy way to remedy this?
triumphrick
Re: 1994 Yami ProV 150, pulls hard to the right
Assume that you have checked for the obvious? Is the lower skeg straight, no damage or bends? How about the anode skeg? They can be used to adjust off center to correct a pull. Also , depending on your steering cable, most teleflex cables and steering wheels can be centered by removing the steering wheel nut, pull wheel out and reinstall at desired angle. Good luck!
Olin83
The lower skag is perfect. I just read another post that said to rotate the anode skag against the pull. I am new to high HP motors and didn't realize what that was for. I'm going to adjust that. I tried removing the steering wheel already but it's all plastic and their is nowhere to use a puller. It's on so tight i'm afraid i'll break it if I pull any harder.
Yamajoe
readadjust your trim tab before you touch the steering set up.
