cumminsford
Thread starter- Joined
- Nov 18, 2005
- 2
This is my first time to the forum.Hello everyone.I hope to find some help here.I recently aquired a Gregor 15' with Yamaha 30 console controls.The first time out the boat had problems shifting from idle into gear-it would die.So i checked the primer bulb,changed out the existing fuel with new,and replaced the existing spark plugs (which were one heat range lower than Manufacturers spec)so i figured that might have been it.So today i take the boat to the lake,it fires up and idles fine,i cruise it half throttle (15 mph) for about 2 miles.I stop and shut down,re-start is fine,into gear and full throttle about 5 miles or so,stop and shut down.Wait 5 minutes,motor dosent want to start,let alone idle.I raise choke lever to start (warm up) an already warm motor,and manage to get it into gear with out the motor dying (this is the main problem)and finesse us back to the dock.Im thinking the carbs need to be fattened up a turn or two,since the choke was needed to start the warm engine.Any experienced opinions here?I have gotten conflicting advice on number of adj screws,etc.This motor has 3 carbs with one adj. screw near the top of each carb,mounted on the side.I have looked on line and at local dealers for a manual but they are all out of stock.I sure could use some help.Thanks,Mark.
