Eric Johnson
Thread starter- Joined
- Apr 29, 2013
- 6
Engine bogs down/ shuts down on plane. When at idle runs fine. Felt the primer bulb while running did not feel much gas going thru the bulb, Bulb is not hard or soft when ruuning, somewhere in the middle. how firm should the bulb be when running? Have NGK plugs in it right now will change to champions next. Where is the fuel seperator located? will try that also, along with spraying the carbs. What should I use? I have Sea foam in gas now, not sure if it went thru motor as of yet though. In other words Help!!!!!!!!
