1994 Johnson 200 power head removal
Mriplaybass
A few years ago, I had a rod blow a hole in the crankcase. Now that I'm retired, it's time to fix it! The problem that I am having is getting the power head separated from the lower housing. I have disconnected everything that needs to come off. I have removed the lower unit. I have removed 4 bolts and 1 nut on each side of the power head, and 1 nut at the rear above the exhaust. When I try to lift the power head off, the entire boat and trailer lifts up. I tried putting the front 2 nuts almost all the way on, then with tension on the lift, pried up on the nuts. Nothing! The power head won't budge. I tried gently heating with a propane torch around the gasket under the power head, but this did nothing. Right now, I am trying to use a razor saw, and split the gasket that way. Very slow going, and I don't think I can reach all the way around.
Does anyone have any ideas on how to break the power head loose? According to the shop manual, I have everything loose, or am I missing something?
Faztbullet
Take the remaining bolts out !!!! 2 nuts and 2 bolt in front,3 down each side ,1 nut on rear
Mriplaybass
That's what I already did. The only reason that I loosely put the front 2 nuts back on was so that I would have something to pry against between the stud and the transom mounting bracket. The nuts were about 1/8" from making contact with the lower housing. I only did this after removing all the nuts and bolts and trying to lift the power head off.
As I said before, the only thing that I can think of that's left holding things together is the gasket between the power head and lower housing, but I have never encountered one this difficult to break loose. I can't imagine that I'm the only one to encounter this, but it seems like Murphy's law strikes once again!
daselbee
Have you noticed the two bosses on the back of the block that are there for prying purposes? They are heavy, large castings of metal down low right next to the exhaust adapter. The exhaust adapter has the similar bosses cast in. You can get a large crowbar right in there, and try separating. There are two of them, on the back of the exhaust chest, low down to the exhaust adapter. (My description sux, but try looking anyway.)
As Fazt says...be sure all bolts are out. I think he is describing the same number of bolts you are...but cannot be sure. You are counting one way, he is counting the other....
You don't mention the six big ones that hold the block to the exhaust housing. They are about 9-10 inches long....you got them right?
Mriplaybass
I know the pry points that you are talking about. I removed 4 bolts and 2 nuts on each side, plus 1 nut at the rear between the exhaust tubes. This is what the shop manual says to remove. 6 of the 8 bolts are about 1-1/2" long, and 2 of them are about 2" long. So you are telling me that the 6 bolts that are about 2" below the other ones have to come out too? Even the manual doesn't say to take these out! Even though it is a cold windy day here, I'm going to go out and try these 6 bolts.
Mriplaybass
No luck! I loosened all additional 6 bolts to provide about a 1/4" gap under the bolt head and hooked up my engine hoist. I put more pressure than I ever have before. I pried on the pry points to the point of causing the exhaust housing to deflect. Still won't budge!
daselbee
YES! They will be long. 9 10 inches.
EDIT: I see you still cannot get it off. Remove one of those six bolts to be sure we are talking about the same bolts. Examine for 9 inches or so.....
If you have the correct six, they must come out anyway. So instead of loosening them, take them out and then try again.
Mriplaybass
Tried again. Totally removed the 6 long bolts. I put as much strain on the lift ring as I dared and it still wouldn't move. Then I pried on the right front stud that I left the nut on and YEEHAA! :clap2: The power head came free! So, after doing the dance of joy in my driveway, :bounce: I rolled the lift and power head into my shop where the engine now sits on my bench awaiting disassembly and diagnosis. A whole new can of worms I'm sure.
Thanks for the help! :D
