Wombat_One
Thread starter- Joined
- May 9, 2002
- 2
I just bought this motor and used it a few times. The past 2 times I have taken it out, the warning horn has come on, but only at high speeds. If I keep the RPMs down and the water pressure at or around 30 PSI, the warning horn don't come on. I can ride it like this all day. Once I open it up, the water pressure gage pegs and then a minute or so later, the horn sounds, and slows down to 2500 RPMs,(as it should). I shut it down and let it sit for a few minutes and it starts right up with no horn. I am confused because there is plenty of water coming out the engine, so is it over heating or could there be a sensor that is bad??????
