1994 Johnson 140 Oil Injection Wiring.
olioliumphry
Yes Scott, I knew what you meant and you make a very good point about the tank. The tank that's in now looks a bit rough. It also looks like there was some hardware attached to the top at one point. there is telltale signs and bolt holes. What was there....I have no idea. Can anyone suggest a place to purchase this unit online?
flyingscott
0175953 is evinrudes tank kit #. 0175954 is the pickup # This website should have it or ebay. But I would double check the part#s got to evinrudes website and find you specific model#. Or type in your model# on this website. There is a $40 difference between the 2. I have no idea what the extra holes are for but all the tanks I have seen have them not to worry.
olioliumphry
Ok thanks. I would just like to clarify one thing.....This sensor is the sensor that detects "low oil" only, correct? So the no-oil and the high temp sensors are not affected by this black wire being cut, correct? This is, of course, providing everything else is working properly.
flyingscott
Correct low oil only. You will be able to test the no flow sensor when you replace everything
olioliumphry
For informational purposes, this is what I've found....Tank kit 0175953 has been replaced by 0176787, and Pickup 0175954 has been replaced by 0176636.
Gee, if your '94 Johnny is like my '98 Johnny 150HPV6 (60* V), the low oil sensor is a simple float switch. When the oil level gets too low, the tan sensor wire is grounded to the black wire, and the alarm sounds. The logic of the "System Check" tach or light determines whether the alarm is continuous, beeps or whatever.
I would look for a place in the wiring harness where some wires have melted together, and you may find where your ground wire is getting that +12VDC from.
