1994 Johnson 140 Oil Injection Wiring.
olioliumphry
I just bought a used boat with a 1994 Johnson 140. Everything appears to be of working order as I have had the boat out for it's maiden voyage. Runs like a champ. However, I had the cowling off today and noticed a "cut" wire that goes to the injector tank. It's a black wire routed with a tan wire from the tank that appears to go into the main wiring harness on the engine side. Seeing this made we wonder about the low oil/no oil alarm. So I reconnected the black wire and now when I turn the key on I get a constant alarm. No beeping, just continuous.
I pulled the tan wire off the horn and it stopped, so I assume the horn is good. Plus I get the standard short beep when turning the key on when the black wire is disconnected.
There is one thing that throws me....with the black wire disconnected at the engine, battery and key on, I get 12v coming from the tank, not from the main harness. How is the black wire being fed at the tank if the tan wire is a ground? The only wires coming out of the tank are a black and tan.
Any help would be appreciated. I'm good with mechanical stuff, not so much with electrical.
sutor623
Well, not sure how you are getting 12v, but one things for sure, I would disconnect the VRO , plug off the oil port on the pump, and premix until you get it sorted. Sounds like the previous owner cut the line to silence the alarm.
olioliumphry
Yes, the VRO is hooked up and apparently running ok as I had the boat out running for an hour or so. So is this the same tan wire that goes to the temp sensors?
And I really do not want to remove the VRO. I know the pro and cons and would like to keep it.
olioliumphry
Additionally....I will get this sorted before it goes back out. That's why I'm seeking help. If I can't, I'll disconnect.
flyingscott
Yes the tan wire is the same they all connect to the horn. My guess would be a bad tank sensor it tells you when the oil is low they go bad and will cause that problem. Or there is a short in the tank wires somewhere .Your no flow sensor should still be working as that comes from the pump harness and plugs in to the motor harness. You have a vro2 I would not worry about the pump to much but i would fix the sensor if that's the problem.
The alarms for the motor are this
1 beep every second no oil flow shut down now
1 beep every 20-30 seconds is low oil
A solid alarm is overheating
There might be one more for fuel flow I don't know if that was put on the 4 cyls or not.
olioliumphry
Thank you flyingscott. With the black wire being "cut", would that mean the high temp alarm is disabled as well?
olioliumphry
I tried grounding them to the engine and got nothing. I'm wondering if I should take this to a mechanic. Problem is, I don't know a reputable one.
sutor623
But Scott, the odd thing is that it is a solid alarm. I was thinking there was a faulty alarm in the tank too, but then it would likely sound like the low oil alarm rather than the overheat/low fuel flow alarm.
olioliumphry
Plus I'm still very confused why I have 12v coming from the black "ground" wire from the injector tank.
olioliumphry
Is this a possibility?? If the horn is sounding and there's power going to the horn, could the power be back feeding due to a short into the in-tank sensor and supplying 12v to the ground wire? If I'm explaining that right.
Honorary Supreme Mariner
Maybe the horn itself is defective !____1 mile away or a 1000 miles away I can not see the horn that you have here.
Fed
You have a short circuit in the tank sensor or the wiring to the tank is shorted.
The tank sensor is not a simple on/off switch like the temperature sensor.
The tank sensor has electronic gadgets that create the 30 second chirp.
The tank sensor should have 2 wires, one will come from an existing Tan and the return wire (the cut one) will go back to a ground.
With the Black return wire cut you would expect to get 12V on it with a shorted sensor.
If the sensor wasn't shorted it would not sound or it would only chirp every 30 seconds.
With the key in the ON position grounding ANY Tan wire should sound the horn continuously.
olioliumphry
Thanks Fed. I'm starting to see the picture. Is there a definitive way to check the tank sensor?
flyingscott
The tank sensor has power to it because it's a timed switch which is why it beeps like any switch it can short out. If you have power to the ground it's probably because the switch is shorted and letting power through which is setting off the warning horn. Easy to check make sure the oil tank is full and disconnect the tank sending unit harness and check for continuity if you have continuity bad sending unit. Because you have 2 wires you have a hot and ground 12volts. Like I said you need to check for shorts but with that harness cut and the sensor cost is around $150 easier to cut.
olioliumphry
Yes Scott, easier to cut, but not for me. I want it to function. I'm a bit anal about those things. 150 buck to potentially save my engine is a no brainer.
Fed
You have already checked it by disconnecting it & the horn stopped sounding.
Because the return wire was disconnected and the horn stopped that means there is no short to ground on the feed wire or within the sensor.
A short to ground on the cut return wire wouldn't matter because it's supposed to be grounded anyway.
FWI my tank sensor wiring is a black twin figure 8 cable that simply plugs into the loom by memory.
olioliumphry
Lol...I understood about half of what you said Fed. But I am understanding that the sensor is bad. I will replace and post the results. Even if it's not bad, I plan on keeping this boat for a while. She's in pretty good shape.
Thanks everyone for your help.
flyingscott
Hello I didn't mean you cut it. I meant PO cut it to save the cost of the sensor and left you with it. Do not buy the sensor used spend the money and get new. You will get a whole new unit with a filter and you will need to follow the re-priming procedure for the pump when you change it. You may also want to look at a whole new tank assembly as it's about $50 more and everything is new.
