olioliumphry
Thread starter- Joined
- Dec 10, 2015
- 13
I just bought a used boat with a 1994 Johnson 140. Everything appears to be of working order as I have had the boat out for it's maiden voyage. Runs like a champ. However, I had the cowling off today and noticed a "cut" wire that goes to the injector tank. It's a black wire routed with a tan wire from the tank that appears to go into the main wiring harness on the engine side. Seeing this made we wonder about the low oil/no oil alarm. So I reconnected the black wire and now when I turn the key on I get a constant alarm. No beeping, just continuous.
I pulled the tan wire off the horn and it stopped, so I assume the horn is good. Plus I get the standard short beep when turning the key on when the black wire is disconnected.
There is one thing that throws me....with the black wire disconnected at the engine, battery and key on, I get 12v coming from the tank, not from the main harness. How is the black wire being fed at the tank if the tan wire is a ground? The only wires coming out of the tank are a black and tan.
Any help would be appreciated. I'm good with mechanical stuff, not so much with electrical.
