dreese2005
Thread starter- Joined
- Aug 21, 2010
- 34
So, Everyone has been extremely helpful on the others issues I had. I have now officially torn down and done a ring job on my first outboard. As suspected by everyone, The rings on the #3 piston were broken and gone. I have now torn it down, honed and miced the cylinders, replaced the bad piston and all of the rings, along with rebuilding the fuel pump. it will now start and run. It will idle for a little while but seems to be backfiring a little back through the crank case. I am at this point assuming it is a timing issue. Maybe an idle adjustment problem or possibly both. It starts much easier than it did before and I can make it idle fast by advancing the timing. by hand. It has 2 fixed jet carbs so I dont believe other than idle speed and timing there is mucht to a "link and sync" my question is what should the timing be at on this motor at WOT and I should I check the timing on cylinder # 1 correct? I Should set timing at WOT correct? Is there a need to set it at idle also?
BTW new rings now compression check shows #1 95lbs #2 95lbs #3 98lbs, #4 92lbs
Thanks for your help
