1994 Johnson 112 Timing.
dreese2005
So, Everyone has been extremely helpful on the others issues I had. I have now officially torn down and done a ring job on my first outboard. As suspected by everyone, The rings on the #3 piston were broken and gone. I have now torn it down, honed and miced the cylinders, replaced the bad piston and all of the rings, along with rebuilding the fuel pump. it will now start and run. It will idle for a little while but seems to be backfiring a little back through the crank case. I am at this point assuming it is a timing issue. Maybe an idle adjustment problem or possibly both. It starts much easier than it did before and I can make it idle fast by advancing the timing. by hand. It has 2 fixed jet carbs so I dont believe other than idle speed and timing there is mucht to a "link and sync" my question is what should the timing be at on this motor at WOT and I should I check the timing on cylinder # 1 correct? I Should set timing at WOT correct? Is there a need to set it at idle also?
BTW new rings now compression check shows #1 95lbs #2 95lbs #3 98lbs, #4 92lbs
Thanks for your help
interalian
Rather than trying to time it at WOT, look in the top sticky post on this forum for the Joe Reeves timing method. For this, you set timing while cranking the motor, holding it 4 degrees back from the rated timing. Works well.
If you're running it on a hose, you'll get a lot of popping through the exhaust since there's no backpressure.
dreese2005
Thanks for your help.. I will try this method. I will be taking it to the ramp this afternoon to complete this as I want it to sound right and have the proper head pressure during the process. Thanks again
Bosunsmate
After ive done a rebuild I always ground the ht leads and turn the engine over a few times with the starter and then remove the sparkplugs and check they a wet with fuel. Running a cylinder dry after all that work would be close to infuriating.
If timing is way out you will need to check your flywheel key. That does need to be tightened down to around the correct torque.
Another thing that can happen is that the ht wires have being put on the wrong spark plug, ive done that more than once myself
jakedaawg
Is it a lean pop? If so, what product did you use to seal case halves?
dreese2005
So Jakedaawg, I did a bit more looking this afternoon... It is in fact popping through the seam of the two halves... maybe I didn't seal it quite as well as I thought... so here's my question. since these are fixed jet carbs, is the bad seal itself causing the pop or something else, Timing? causing it to pop and spit out the seem? Either way I know it has to come back apart... just wondering if there was another issue to look for or if the bad seal in itself would cause the popping.
dreese2005
Thanks for your response.. I have the timing set and it has fixed jet carbs so I thought that might be the issue..
Bosunsmate
No worries, to seal crank halves i use permatex aviation form a gasket, its cheap, comes in a small bottle with a brush and its never let me down
jakedaawg
Yes, unfortunately you will have to tear it down again. Sorry....
The last one I put together I used some yamaha product cause I was out of everything else....I think it was 4 bond grey but not sure and I am in Fla on Vaca for a month and away from my manuals and shelf of stuff....again, I apologize....
Someone on here will be able to look up the proper product.....
While you have it apart place halves on plate glass and check for warpage maybe.....Seldom have I found a leaky one when any suitable sealant is used....
dreese2005
Thanks to Everyone for your help... I will begine tearing it down again next week...
daselbee
OMA....the proper stuff to use is OMC GelSeal II. The equivalent product is Loctite 515 Flange sealant. Tearing it back down is too much work to leave the sealing to just any sealant.
