1994 Force (Mercury) 9.9 HP serial #OE105918
sullmate
This engine has low hours, new plugs, new t-stat, new impeller, new lower unit oil. It started right up. It ran for about 10 minutes a full speed, then ran for another 10 minutes at only 1/2 speed, then died totally. Gas and oil were fresh. Tried to pull start with spark plug removed and grounded to the engine block. Saw spark on only 1 cylinder. Seems like the ignition coil?? Please give me your suggestions. Thanks
jerryjerry05
CDI ignition. Call them for test procedures.
But it sounds like a coil packs gone bad??
But get it tested.
sullmate
Jerryjerry05. Are there 1 or 2 ignition coil packs in this engine??
Nordin
Sullmate it is two coil packs in your engine.
One for each cylinder, these coil pack is ignition coil and power pack in one unit.
Still available from Mercury part number 850899T.
CDI Electronics aftermarket unit 300-850899T N/A.
