I have a 94 bayliner with a Force 120 engine. I bought it from a friend, who said it just didn't have any power when given gas. He had a local marine rebuild the carbs, and I bought it. I put fresh gas in it and took it out and the carb work didn't work. It'll start fine and idle around fine, but when given half or more throttle, it just won't plane out. It DID the first time I took it out for 30 minutes, but hasn't since. It's getting fuel it seems, the bulb stays firm, and all the lines are new. I did notice after coming home this last trip out, that the #2 plug down is clean, and when I touched the boot to it when running it shocked me. I replaced the voltage regulator with no change. Could it be a simple plug boot that I need? If not, what, coil, or CDI module? Any help is appreciated.
Thanks
Brandon
Thanks
Brandon
