1994 cajun 1850 fishmaster prop
vetdoc1
I recently purchased a 1994 cajun fishmaster 1850 with Johnson 150. What prop would you recommend for general use?
Ron G
Re: 1994 cajun 1850 fishmaster prop
they need more details,go above to posters it'll tell ya what put down,welcome to iboats.
Before investigating a prop swap, make sure the engine is performing properly. Prop changes cannot compensate for a poor performing engine. Then you need to determine what prop diameter and pitch you currently have and what the wide open throttle RPM is with normal load using the current prop. Then you need to check engine height (X-dimension) to determine if its optimum with the current prop. If the engine then turns at its maximum recommended wide open throttle RPM, you already have the optimum prop. If its under that RPM you need to decrease pitch. If its overreving, you need to increase pitch. Engine RPM changes 100 - 200 RPM for each 1-inch of pitch change.
walleyehed
Can you give us some numbers with the current prop??<br />What prop is it and what size?<br />What RPM are you getting at WOT???
vetdoc1
Sorry. Currently getting 5400 rpm. Stilletto (spelling)stainless but can't find pitch numbers. Boat weight 1600 pounds.
walleyehed
Is the engine mounted in the lowest possible location, or is it up some (which holes are being used at the top).<br />The prop numbers should be under the nut and washer....should be a number like 20319 or something close to that...
vetdoc1
Motor is mounted in top holes. I will look for numbers again at lunch. Thanks
vetdoc1
prop numbers is 20317 01417 motor is mounted on top holes. Boat does torque when accelerated with motor trimmed down. Thanks
walleyehed
Stiletto 14-1/4X17 pitch..This prop will handle some higher running heigth.<br />Need to raise engine 1 hole at a time and test.<br />I "think" you'll end up in the third holes down and 5600-5700 RPM in that location.<br />Is the prop in good condition???
vetdoc1
There are some dings. This is the reason for asking. I was thinking of purchasing new prop. Thanks
walleyehed
Well, repair is always a possibility...Or, if you do buy new, I would stay with the stiletto in the same size.
vetdoc1
Raized engine to third hole this weekend. Did help. Thanks for info.
