I have a 1994 Bass Tracker TX17 with a Johnson 60HP. The problem that I'm having is when my boat is parked or going down the road, the outboard motor will raise all the way up by itself. I have unpluged the outboard tilt/trim switch and it will still raise up on it's own. If I go outside and let the motor back down, it will raise up on it's own within 10 to 15 minutes and sometimes less. I checked the bow tilt/trim switch and thought a wire was loose so I made sure I had a good connection and the problem seemed to stop for a couple of days, and then the motor raised up on it's own AGAIN..
Can any give me any ideas on what I might be dealing with and if it might be the tilt/trim swich in the throttle ? Any help would be appreciated.....
