1994 Bass Tracker TX17 "Crazy" Tilt/Trim Problem !!
Bobby564
I have a 1994 Bass Tracker TX17 with a Johnson 60HP. The problem that I'm having is when my boat is parked or going down the road, the outboard motor will raise all the way up by itself. I have unpluged the outboard tilt/trim switch and it will still raise up on it's own. If I go outside and let the motor back down, it will raise up on it's own within 10 to 15 minutes and sometimes less. I checked the bow tilt/trim switch and thought a wire was loose so I made sure I had a good connection and the problem seemed to stop for a couple of days, and then the motor raised up on it's own AGAIN..
Can any give me any ideas on what I might be dealing with and if it might be the tilt/trim swich in the throttle ? Any help would be appreciated.....
UMPIRE72956
Re: 1994 Bass Tracker TX17 "Crazy" Tilt/Trim Problem !!
i have a 93 with the exact same problem. Have you found out anything?
UMPIRE72956
the problem is water on a switch or just a bad switch. i undone the front switch and the one one the motor and tested it. it worked fine. start plugging them in one by one checking to see if that is the bad switch mine just happened to be the front switch. hope this helps.
flseanc
i know your post was from a while ago, but i was on here looking for info on my steering problem & saw your post.....i just went through the exact problem on my tracker 185 pro team. the issue on mine was caused by bad relays not switches. on my boat there are 3 places you can trim the motor from...the very front (by the trolling motor), the throttle, or on the side of the motor (90hp merc). if you follow the wires from the switch on the motor they will lead you right to the relays. took me about 2 minutes to install them & it was just over $30 for both of them.
