1994 70hp not enough fuel?
boydog40
my 70 hp at idle is not running on all 3 cylinders, as soon as I give appx 1/4 throttle (more gas) she clears up and you can feel/hear all the cylinders firing then.
what is causing me not to get the correct amount of fuel at idle?
Mas
Re: 1994 70hp not enough fuel?
low speed is gummed up
ryan04
yup, sounds like low speed goo.
boydog40
thanks guys ordered new carb kits and will install tomorrow, will squirt slow speed out with carb cleaner (unless otherwise advised) and report back
thanks for the help
Mas
Use compressed air and a very fine wire.
MAS
boydog40
ok will do on wire and air
correct me if I am wrong on the correct setting of low speed jet when I reassemble, bottom the needle out and back out 1-1/2 turns?
