1994 70hp Force by Merc Marine ~ Alternator?
djjones64
Hello ~ 1st time boat owner, 2nd forum post regarding battery charging. So, does the 1994 70hp Force come with an alternator that charges the battery or do I need to invest in a battery tester/charger?? Thanks.
flyingscott
The motor has an alternator that charges the battery no need to buy one.
roscoe
So now the question is .......... Is it working?
jerryjerry05
It's supposed to charge itself.
​But!!! if the battery goes dead over time, the radio or depth finder might be killing it.
You can install a volt meter in the system.
Get a battery load tester(Harbor Freight $25) and a hygrometer.
That's 2 of the handiest tools I use.
There are many options for battery testers, chargers.
I have a big shop charger with a 200 amp jump,30 amp quick charge and 2amp trickle charge.
I also have a battery maintainer that sets on a shelf( don't trust it??? )
One easy test is using a simple test light.
It tells you if there is any draw on the system.
Turn everything in the boat off.
Unhook the ground lead on the battery.
Install the tester between the N post and the end of the cable.
If the tester lights up??? then there is something drawing on the battery.
Then go through and pull the fuses or unhook the accessories and see what circuit stops the light from burning.
