FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
My starter spins rapidly when I turn the key however the gear is not engaging the flywheel noticed some smoke coming from it when the starter was turning.....is there a fix for this other than replacing the starter..... appreciate any help.
Lube the bendix shaft. Use a very small amount of a light grease. I used to use a drop of a light oil, but I read that it's better to use grease because starters can fail after enough oil seeps down to the brushes.
Just in case you don't know what a bendix shaft is, it is the shaft the starter gear that should engage the flywheel is on. LOL. Bendix isn't even on my spell checker so probably not a common term anymore although correct. Best of luck. Rick.
