jay jasper
Thread starter- Joined
- Aug 8, 2020
- 8
1994 2452 with 5.7 liter, 4 barrel with Bravo 2 outdrive. Engine serial number 0f274795
As far as I know, it's a Thunderbolt 4 with the "intensifier", or what ever it's called, on the distributor not the exhaust manifold.
In a nut shell: I had a cooling hose blow out. I turned the motor off, attempted a repair and started it again. The repair failed and I turned the motor off and got a tow. It was salt water.
The motor never killed on its on.
The boat sat for a couple of weeks waiting on a complete hose update.
The motor will now turn over, but will not start. There is nor sign of salt water intrusion in any of the connections, including the main harness plug.
Brand new plugs. I do get a spark at the plugs, which are the exact plugs the manual calls for. AC Deloco MR43T, gapped at .035 The spark is blue and orange.I would like to see blue...
I get 12v at the coil and it doesn't drop below 10v when cranking. I have run a direct line from the coil to the battery which did no good, as changing the coil did no good.
I tried starting with the tachometer disconnected.
I am getting the correct voltage to the sensing unit, which is brand new since this issue.
One difference is that the new unit has a ground, whereas the old did not. I have tried it with the ground grounded and with it not grounded.
The rotor and distributor cap looks good.
The plug wires are less than a year old.
I have even tried starting fluid. I'm losing my mind! Who's thought an old small block Chevy could get complicated!
Awesome site, hope someone can help.
