Hello all! This is my first post and also my first major boat project that I have undertaken. I noticed a small soft spot in the floor at the walkway to the bow. I proceeded to tear the floor up and found that the flotation foam was soaked and the was a little bit of standing water at the bottom of that compartment. I tore out the foam and removed all the water. The stringers on the left side seem to be solid bu the one on the right has some surface rot. I have torn out the rest of the floor and it seems that the rest of the stringers are in pretty good shape. My question is it ok to cut or scab a section of the stringer and re glass it if the rest of the stronger looks in good structural shape? Also when installing foam is it better to do it before the floor goes down or after and what materials are the best on the market for the price
Any advice is welcome
Thanks
Dave
Thanks
Dave
