1993 mercury outboard
trider
I have a 115hp 1993 mercury outboard that idles fine but when I get the motor opened up full throttle it will run for a minute or two and then it feels as if one or two cylinders will shut down for a few seconds then it will pick its self up again. Any suggestions or tips or what to check or look at would be appericated...
CharlieB
Re: 1993 mercury outboard
First thing is to squeeze the primer bulb as this is happening to assist the fuel pump, if it improves the condition you can be pretty sure that you have found a problem with the fuel pump providing sufficient fuel for WOT.
Rebuild the pump.
trider
I took the hood off the engine and pumped up the fuel bulb and noticed fuel dripping out of the fuel pump could this be part of the problem and also my serial #number is od124746 trying to find out what year them motor is to order parts thanks for the help
Jacket4life
Sounds like a bad pump diaphragm. Did your serial # show up in the stickied post at the top of the page?
trider
Yes that sticky at the top of the page helped me thanks did not pay attention to that
CharlieB
Pick out our serial # here
http://www.mercruiserparts.com/selectSerailRange.asp?doc_nbr=115+(4+CYL.)
Look up the Mercury part #, then decide where you want to buy your parts.
Notice that there is TWO different fuel pump available, look closely at the position of the check valve in each, then compare to the one on your motor to be sure you select the correct pump diaphragm kit, they are NOT the same.
Once you have the kit part # then you can check the iBoats parts supplier using the Merc # to cross reference.
trider
well after figuring out this is a 1991 year model i can push it to 6000 rpm If my gauge is right ) . what benefits would i get by changing my prop to stay around 5000 to 5500 rpms. thanks for all the info i greatly appericate it
Jacket4life
Np. It's just that a lot of new ppl get on here everyday and ask the same questions over and over. I think they should MAKE you read that sticky at the top when you register, myself. It tells you how to search the forum, etc.
Best of Luck, and I wasn't trying to preach!!!
