bearstalker
- Mar 21, 2011
- 2
I notice that the choke butterflies don't open fully. Is this a cable adjustment problem? I move the throttle arm through its full range of motion and they still don't open. This is the four cylinder model, cylinders stacked one on top of the other. The motor sat in storage for a season before I picked it up. What throttle setting should I use for starting? Also, there are two switches on the throttle and shifter control unit, one switch right above the other? Why two switches. Last question: There is no choke, only a primer button. How many pushes on the button, and should I be seeing air in the primer lines? The air seems to work out of the lines after several vigoruous pushes.
Thanks for you advice.
