1993 johnson120hp vs 2000 johnson 150hp
wilson750
Looking at upgrading my 93 motor to a used 2000 150 johnson. just hope that 30 more hp i will see a notice..I can not find the weight of both motors.Also is the wire harnes the same on a 2000 150hp as the 93 120hp? Also are the 2000 year motors as good as the 93's? I didnt know how much change was done by 2000 besides the looks..I have anyone has any input that would be great.
I have a 93 Hydrasport 1850 vector wich is a very heavy boat and I looking for more get up and go power from a 150hp..
Thanks
Faztbullet
Re: 1993 johnson120hp vs 2000 johnson 150hp
Both motors are within 10lbs of each other and you will need a adapter harness(part# 176349) The 2000 60? 150 is a good engine.
wilson750
Will I see/feel a good difference in the swap? The 120 runs great, I Just want some more power, and a 150 is the max for the boat.
Thanks for the help with the adapter.
Also The owner wants around $3000.00 for the motor.I thought that was a good price. Any idea what I can sell my 93 120hp for?
Thanks
Faztbullet
You will see a big difference thru all the rpm ranges. If your 120 has the "big" gearcase on it the gear ratio is different and you may need to play with prop pitches but if it has the standard V-4 housing you will need a different prop as the 150 can swing a bigger diameter prop..
reiddo1
Thanks
I have a 2000 ocean pro 150 hp which replaced a 1979 evinrude 200 hp; I can tell you that the 150 is as good as the 200 hp with respect to power and speed. If you have good compression on the newer engine, you will be pleased with it. Good luck
wilson750
Thanks for the advise guys..Now i just need to find out what I can sell my 120hp for..Cant seem to find a used one for sale anywhere.
Got the weights on NADA. I dont think they are to close with the price of motors though.They seem to be really low on all the motors.
wilson750
Does this harness go inside the motor where the harness clips in?
wilson750
Bought the motor today..The compression on all 6 was 106-110. Hopefully that is some good numbers.Motor is super clean. Very excited to see how she runs with this beast!!
