My 1993 johnson 200 is running on port cylinders only. Three starboard cylinders are dead. Checked the stator and am getting 125 volts on one wire and 117 on the other. From what I understand this should be enough. Pulled the powerpack but I am scared to just start changing parts. I heard that the neutral safety shuts down the starboard three cylinders. If I unplug it will it bypass it. I read about a diode problem with that. Any help would be greatly appreciated.
