1993 Johnson 70 Timing
Wide_N
VJ70tLETS. Wasn’t getting fire so replaced timer base and power pack. Both were bad. Now have string fire on all three. Compression 125 on all three. When I prime little fuel in the carbs I get a backfire and no start. Acts like the wires are out of order but I’ve got tan/blue on top, purple middle and green bottom. Any ideas what else I might try?
Flywheel key could be sheared.----Did you torque it properly ?----Assembled it clean and dry ?
Wide_N
The colors all match up. Power pack and trigger are both new.
Wide_N
Put a timing light on it and I’m 180 degrees off. Pin is not sheared.
Wide_N
No sir. They are correct. And if they were at least one mark of the three top dead centers I made would hit right? Or at least be close. Top dead center is when the piston is closest to the plug correct?
Perhaps the magnets around the hub are loose.-------Note a sheared flywheel key will still give you beautiful spark but just at the wrong time !----I do not understand how a powerpack and timer base can both be bad on one of these motors.
Wide_N
They were both bad. I have a DVA. Two different shear keys and two different flywheels have been tried with the same results.
Wide_N
CDI tech support thinks that it could have gotten wired wrong in the pack. He suggests trying to switch the wires up.
Wide_N
Got a better timing light. All three cylinders are firing at the same time.
Wide_N
Let me rephrase it. They are all firing on the same cylinder. I marked it with numbers. It lit 1 the 2 then 3 really fast. Pulled it apart now anyway for parts. Thanks.
