Re: 1993 johnson 60hp carb rebuild tips needed
I am not familiar with your carbs exactly.<br /><br /> But, they are similar to some I've done , I'm sure.<br /><br /> The best tip , would be get a manual for your motor.<br /><br /> You'll want to do a lync and sync, after the carbs are done. At least I would .<br /><br /> Everything is in the manual.<br /><br /> Make sure you soak/ clean REAL WELL.<br /><br /> Making sure all orifices/ jets etc. are clear and clean.<br /><br /> Blow out with compressed air, then install your kits.<br /><br /> If your carbs have the welch type plugs. <br /><br /> A sharpened, old screwdriver , punch . Works great, just drive it through the plug, and pop it out.<br /> <br /> Be carefull, not to drive it in too deep.<br /><br /> Good-Luck,<br /> <br /> KYHunter
