1993 johnson 150 engine block rebuild question
alumacraftmvtek
i am getting ready to rebuild my johnson j150elatr. The block cracked on my original engine. I called ********** and i know that the 150 block is obsolete. I am aware that they are the same block as 175. i gave them my original block part number(432999) they sent me a replacement block part number (438906). The new block i have gotten from ********** look the same except if you are looking at the cylinder holes on the right side there is a nipple at the top of the block where the rectifier screws in the block and another nipple almost at the bottom of the block to the left of the bottom cylinder hole. I have done some research on this and this seems to be a evinrude ficht block. I know that this block served many years and many models and from what i have researched these nipples are for a water vapor seperator. My 1993 johnson did not have a water vapor seperator on it. So my question is can i use this block? I have ordered all new rings, gaskets, etc. For my application can i just run a hose from one nipple to the other like a bypass more or less or can i just plug those nipples? Any thoughts or anyone run into this before?? thanks.
boobie
Re: 1993 johnson 150 engine block rebuild question
Call ********* and ask them about it. They should be able to tell you.
alumacraftmvtek
Thanks I was gonna call them tomorrow but thought I would try just to see if anyone else has ran into this
Faztbullet
The only way you can use it if a fitch block is if you do some major modifying. You will have to use the fitch starter drive gears as bushing in block is offset .250, modify lower recirc drain block as different, use the fitch shift rod as it .500 longer due to cowlings and boss on front half of crankcase,modify your fuel bracket to fit fitch front half as bosses milled different
