1993 Johnson 120 water pump.
goss70
I have a 1993 Johnson 120 trying to replace the water pump impeller. I can only get the lower unit to drop about 1/2". Is there something that is holding the shaft that needs to be removed?
wilde1j
Re: 1993 Johnson 120 water pump.
Have you disconnected the shift rod under the bottom carb?
goss70
No, Is there a diagram somewhere that I can see what to disconnect?
Daviet
You can go to the johnson site and look at a parts breakdown.
goss70
Thanks for the help,
I got it off.
Chris
