JASinIL2006
- Feb 10, 2012
- 5,551
I never found anything that would soften the old carpet glue. I ended up grinding it off.
Did you fold the carpet over the lip of the hole? Not sure, but cut the carpet flush with the hole. If you have to trim the hole out to make it larger, make sure you seal the end grain of the plywood.
Sure, would be nice, my throttle lever is an old type and I wanted to see what did I do wrong putting it back together. ThxI have a PDF for a quicksilver I got from DRS if you need one.
