1993 90hp evinrude V4
monte1021
just wondering what the correct prop would be... right now it has a 13x19 alum prop with WOT it runs about 32 mph at 4000rpms any suggestions? would like to get more speed. engine is in great shape. it is on a 1994 glastron ssv170. me and the wife is about 400lbs plus the actual weight of the boat.. any help would be appreciated.. thanks.. the website says recommended rpms is 5000-5500 WOT
steelespike
Re: 1993 90hp evinrude V4
I think you need to be running a 15" pitch.You might check the height of the motor The antivent(cavitation) plate just above the prop should be a little higher than the bottom of the boat.In the extreme this could gain 2-3 mph and some rpm.
