1993 90hp and 1994 125hp.
Rranger
The short question is will the trim tilt unit from the 1993 90hp serial 0D237792 part number 818903A1 work on the serial 0G086789 1994 125 hp part number 824051. From what I can gather the 90hp is a two wire unit same part number as units used on 1994 125 hp but a later serial number than mine. My 125 hp has the three wire.
My understanding is you need some relays to make the two wire setup work on my unit which was three wire. Would the 1993 90hp have additional wiring maybe the relays, to make the switch?
