1993 9.9 Johnson (j10retm) throttle adjustment
1KINGROOKIE
Looking inside the carb, butterfly not open all the way when throttle is twisted to full. You can push carb linkage and will open all the way up. How do you adjust throttle cable were the butterfly open all the way? Thanks
boobie
Re: 1993 9.9 Johnson (j10retm) throttle adjustment
Is the mag plate advancing all the way ?? Is the roller still on the carb linkage ??
1KINGROOKIE
YES AND YES When the throtlle full you can reach down and push the linkage to full open and the roller has a gap about 1/4 inch.
