ericlindy42
Thread starter- Joined
- Feb 9, 2011
- 16
Hello,
I've been digging through a lot of the older posts to find someone with a similar problem that I'm having. I have a feeling I am going to get a few responses as what I read in the other posts, check compression, check spark, unfortunately I won't be able to do this until April. I'm trying to get a better idea of what the problem could be so I can get right into fixing the boat. Here are the details of my problem.
I ran the boat all summer and it ran fine until my last trip I started having problems with the carb and getting it to idle smoothly. On the last trip of the summer it wouldn't start with the choke so I manually pressed the butterfly valve on the carb to open up just a touch more and it started right up. I did this at the same time someone else was cranking the ignition. After this I went to winterize the boat it wouldn't even start up. I used a little bit of carb starter to no avail. The startor will spin and engage the flywheel as the flywheel will keep spinning, the engine just will not turn over, it doesn't even pop, sputter, or choke. I literally have no smoke coming out the exhaust.
I have checked the Gas, replaced the tank, it is clean. Checked the gas lines, it will squirt out. I took apart the carb and cleaned it up 3 times. It's practically brand-new looking (clean).
I know I can rule out any electrical or startor issues since it will crank and spin the fly wheel.
I'm wondering if it is a vaccuum issue inside not sucking the gas from the carbs? Any advice?
In addition, I have been noticing a bit of black carbon build up/soot that would drip down the outside of the driveshaft housing. It is seeping through the bottom cowl onto the housing.
Please let me know what you guys think or where should I start?
Thanks - Eric
Thanks - Eric
