Disco44
Thread starter- Joined
- Apr 10, 2010
- 53
I have a 1993 60 hp OD187399 with triple carbs, I started noticing gas/oil runnning down the lower unit after pulling it out of the water and puddling up in cover. When I tilt the motor up the bottom carb starts dripping gas that never stops. I thought float could be stuck so I turned gas off and ran the lines dry then fired it back up, the dripping stopped but after I went out and ran it and pulled it back out of the water I could see that gas was running down the lower unit again. I tilted it back up and the dripping started again?? Would this mean the carbs are due for a rebuild? Or could something else be causing this? Any suggestions?
