1993 454ci Sundancer Water Pump
stnick
What a beautiful day on the Tn river today. Unfortunately on the return leg about 2 miles form the slip, my fuel pump went out. At least that's what I thought until the mechanic looked at and said the water pump seal had blown out ( explained the oil mess) and the shaft must have broken that drives the fuel pump. I had confirmed the carb was dry and the boat acted like it ran out of gas.
This is a 93 Sundancer 290 with 381 hours on a 454ci. Just looking for some feedback from someone that has been here before.
Thanks,
Nick
Pete104
Re: 1993 454ci Sundancer Water Pump
Yea, exactly what happens that oil isn't changed.
Your fuel pump is driven off an eccentric in the pump housing. That oil is Merc Hi-Perf. Holds 2ozs. Needs to be changed, atleast once in a while. Perfect time is when the water pump is replaced!
stnick
Thanks for your reply. Who'd of thought you need to change dope in the friggin water pump??? Should have been a big label stuck somewhere!!! Damn I hate destroying stuff due to neglect alone... and this baby is about $550 to make it even more painful.
Nick
