1993 17' Sea Ray 3.0L Merc
Nitrocrusher
I need to find some new parts for the throttle control. The down button on the throttle to raise and lower the prop does not work anymore. Also, the red pull button on the underside of the handle has broken as well as the plastic guide that the tip of it rides in. Can these parts be purchased separately or do I need to purchase an entirely new control? If I do need to buy a new control which one do I get and where is the best place to get it? Thanks for the help and let me know if you need any further info.
Don S
Re: 1993 17' Sea Ray 3.0L Merc
Check with your local Merc dealer, they can get parts for you. Plus, you could look at the pictures to ID your control. The parts aren't expensive, just hard to pickout when you can't really see the unit.
There is also a Service manual for the controls up in the Adults only sticky at the top of this forum.
