1992 VRO2 wiring
Amersci
Hello, I recently purchased a 1993 120hp Evinrude the previous owner was not using the vro system hence the was an old style fuel pump. I purchased a new vro2 pump and tank assembly. My problem is the new pump has a 4 wire plug on it and I have no wiring diagram. I purchased a seloc online manual for this engine went to the wiring diagrams and guess what the power head wiring diagram does not show the vro wiring. Can anyone point me in the right direction as to where I can view a wiring diagram for the vro2 system with a 4 wire pump please? Thank you for your time and attention. Robert
laderwell
Re: 1992 VRO2 wiring
also you need to get a OEM manual... Seloc sucks and please give your model number.The Oem has the wire diagrams in the back
boobie
Agreed, Seloc Sucks. Check the Sticky files at the top of this forum for wiring diagrams.
clanton
This engine had a 4 wire pump when new. Tan, gray, purple, and black wires plugs into connector on engine. Oil tank wire 2 wires 1 to engine ground, 1 to bullett connector tan wire on engine.
