- Apr 17, 2002
- 71,388
Re: 1992 OMC Cobra with no spark
Ayuh,.... It don't matter, so long as #1 plug wire is at the terminal that the rotor is pointin' to, when #1 is firin',...
'n the rest of the wires are in order from #1, in the direction of rotation,....
The 1st step is to roll the motor over, so's #1 piston is Tdc, Compression stroke,...
when you spin the distributor around your just want to spin the inside so the rotor is 180 from where it was not the whole distributor because that would put the hole where the wires come out to the other side away from the coil, right?
I'm still going the read that section but seems to make sense,
