MohaveChuck
- Feb 24, 2014
- 28
Re: 1992 OMC Cobra with no spark
Hmm. That's how it was when I got it but I will definitely try that.
I'll have to take a photo and post but what I have is four wires to the coil. Two on each side. This is the way I got the boat.
A black ignition wire sending 12+ volts and a black wire from the ignition module in the distributor to the positive side.
A wire, that I assume is the ground and a purple wire from the ignition module connected to the negative post. The assumed ground wire is also black and goes into a wire harness with a bunch of wires.
I think it get's it from the ESA module. My thinking is that the grey wire coming from the ESA plug may have the Tach signal on it.It doesn't show any other wires on the coil posts, but personally I thought there should be a Tach wire on the Neg - terminal? Maybe it's on another diagram![]()
That is great guys.
The link took me to the home page so I will do some searching when I get a chance here at work
OK getting spark now but just wants to backfire
Plug wires are correct. I loosened the distributor and rotated it back and forth from position it came to me in but didn't seem to change much.
The negative battery cable is overheating and sparked a little but maybe that's just from cranking it so much?
I'll get in that manual and see how to set initial timing I guess to make sure the distributor isn't 180 degrees off.
Any other suggestions?
