Ride.race.live
Thread starter- Joined
- Jun 29, 2015
- 53
Hey ladies and Gents,
So a buddy and I just recently picked up a sea ray 160 with a 75 merc on it thats been sitting for the past year and a half or so.
We have a couple plans for it.
For starters we will be removing the oil injector system and doing our own pre mix. I had already read on here that we just need to remove the shaft and gear and reinstall the pump is this the correct method? I know other motors have "bypass" kits but doesnt seem like this one does.
We will be flushing the oil from the lower end a couple times until the oil comes out clear.
Will put in new plugs as well.
Is there anything else we should look at while in there? the motor does start and seem to run fine but want to do some maintenance on it and give it a good look over considering it hasnt been used much the past 5+ years and sat the last year and a bit.
ill also add its been properly stored and the motor is more or less spotless considering the year
Thanks!
Jesse
Thanks!
Jesse
