Ride.race.live
- Jun 29, 2015
- 53
So ran into a few issues with my first outing on my boat, 1992 sea ray 160 with a 92 75hp merc
I deleted the oil pump by removing the impeller and shaft I reconnected the oil lines however I cut the line in between the fuel line and pump and capped both of them off.
Drained old fuel put in fresh stuff with 91 oct using lucas semi synthetic 40-1 with a bottle of sea foam.
the issues...
1st I noticed the alarm constantly started to beep... one steady beep and it also did it not running with the key in the "on" position. once in a blue moon i caught it not going off after sitting for a while... I though it may be the the oil level sensor so i disconnected the 2 blue wires but didnt do any difference.
2nd issue - it didn't want to climb RPMS worth 2 shits and more or less maxed out at 3k. It did once in a while climb to around 4200 but took a long time to climb up and it would bog here n there if we gave it too much gas off the start...
the water pump is working it has a strong **** stream so I know its not over heating.
the only thing we changed is we went from BUZHW-02 NGK plugs to BUHW-2 NGK as the BUZ plugs are discontinued
Now I did read somewhere that these motors don't have a "safe/limp" mode?
my next plan right now is to tear carbs out, clean and replace the primer / fuel lines as their a bit older...
the issues...
