1992 Johnson prop size
jc44
I have a 200hp on a 20ft four winns quest center console which has a prop size 15x17. I think my top rpms
Are around 53 to 5400. I hit somthing the other day and had to take the prop in, the guy at the prop shop thought
The prop was alittle to big. I told him I thought the boat performs good. Planes off decent top speed is aroun 35 to 40
He gave me a prop to try. 14 1/4 x21. It wouldn't even plane the boat off and rpms topped at 4400. Any ideas what a good prop size would be for what I have? Thanks.
Re: 1992 Johnson prop size
Sounds like you have the right prop. If you go to a 19" pitch the RPMs will drop to 4900-5000, which is a tad low. Goint to a 15" pitch prop will raise the RPMs to 5700-5800, but you may lose speed. The only sure way is to run time trials.
jc44
Should I go with a lower pitch to get closer to the
6000 rpm range or like you said just stay with the same prop?
Thanks.
jc44
I think the boat weighs around 2500 to 3000 pounds, if anyone has a similar boat & motor set up and is happy with the prop they are running with please let me know what prop you are using. THANKS.
boobie
Stay with the orginial prop or go lower on pitch and see what your rpm's are.
jc44
I just found the original specs for the boat and motor off the four winns site. Their prop specs for this boat and a 200 hp was 14 1/2 x19 pitch. Their top end speed with that prop was 45-49 mph. like you said i would think i would have to go with a lower pitch, what are your thoughts on the 14 1/2 x 19?. Thank you.
Dhadley
Your "prop guy" thinks a 17 is too big so he suggests a 21?????? Really???
If we were doing this we'd go back to basics and look at set up. Then look at what brand and model 15 x 17 you were using. I'd be willing to bet a good 17 would be fine and maybe - maybe - look at a 19.
jc44
I think he was talking about the diameter of the prop (15) was to big. The 14 1/4 x 21 he just gave me to try to get thru the weekend. I want to buy a new prop and use the 15 x 17 as a back up. What brand and model do you recommend and going by the specs i just found what do you think about the 14 1/2 x 19 that the manual recommends? I think max rpms for that motor are 5000 to 6000 rpms. THANKS.
Dhadley
Not all 17 pitch props are created equal. If we were doing the set up we'd test with a 17 Turbo 1 or Stiletto Advantage 1. Set up is alawys the key.
