1992 Johnson 48 SPL Carburetor Adjustment
agaurolex
Anyone have the procedure for single screw adjustment for the dual carb setup. There is no hi lo rpm adjustment for this dual carb setup.
Thanks!
Daviet
Re: 1992 Johnson 48 SPL Carburetor Adjustment
Not quite sure what you are asking, but each carb has its own mixture control screw for the low speed circut. There is a idle speed screw that controls the setting of the engine RPM for proper idle speed.
agaurolex
I didn't word it correctly. What is the procedure for setting the mixture for each carburetor. I saw Joe Reeve's procedure but I am not sure if it applies to this type of carb. I believe this carb is 2 1/2 turns out for the initial setting. But not sure what the next step is for settting the mixture. Thanks!
Daviet
I beleave you are correct on the static setting. You have to set one carb at a time, about 1/8 turn at a time, to get the best idle. It can be a job to set duel carbs, takes patience.
It's best to do this in the water with the boat in the water in gear.
