Taylorsville
- Jul 13, 2010
- 137
1992 Johnson 25HP #J25RLEND. How do I get the lower gear case off to get to the impeller. I need to know how to take the shift lever apart.
If it is like mine i did it real fast. in and out in less then an hour.
Yes Borg......the procedure is identical. Just part of the collective......
Well I didn't think I went cheap. I thought an impeller was all I needed to do. When water not deep enough, What do you mean by that? I have the water over the intake vents. As far as the rest sounds like I need to do some more investigating with the motor. Like the thermostat for one thing i had no idea that would make the water stop coming out of the pee hole.
