1992 johnson 120 tilt/trim
dbr
How, were and what kind of oil do you put in the tilt/trim unit.
Motor and trim unit are on boat.
Dhadley
Re: 1992 johnson 120 tilt/trim
Once the motor is tilted up you'll see the plug on the reservoir (starboard side or unit) and you fill it with fluid until it's at the top of the plug hole. You should use trim & tilt fluid but you can use Dextron.
