Tony T.
Thread starter- Joined
- Jun 5, 2007
- 178
Recently I purchased a 1992 Tracker Pro Deep V 17 with a 92 yr model Tracker Evinrude 60hp outboard, my question is does this outboard have a warm up function? My last boat had a 75hp Mariner and to kick it out of gear to warm up the engine there was a button toward the bottom of the throttle/shifter that you pushed in and that took it out of gear so you could warm up the engine Years ago I had a Johnson 50hp that I believe had a pull up lever while in neutral to warm it. All I see other than the start key/choke is the emergency kill switch, nothing else showing on the controls. Thanks for any info.
Tony
Tony
