1992 Evinrude 60hp
Tony T.
Recently I purchased a 1992 Tracker Pro Deep V 17 with a 92 yr model Tracker Evinrude 60hp outboard, my question is does this outboard have a warm up function? My last boat had a 75hp Mariner and to kick it out of gear to warm up the engine there was a button toward the bottom of the throttle/shifter that you pushed in and that took it out of gear so you could warm up the engine Years ago I had a Johnson 50hp that I believe had a pull up lever while in neutral to warm it. All I see other than the start key/choke is the emergency kill switch, nothing else showing on the controls. Thanks for any info.
Tony
Tony T.
Ok I'll try to get one tomorrow.
Tony
Tony T.
No Title
Post a pic of the control.
Here are some pics of the control and a couple of the motor. Sorry for the fuzzy pics I used my phone camera and it's not the best at times.
Tony
jakedaawg
pull out at the base of the handle and rotate forward for fast advance in neutral
Can you pull the handle sideways to disengage the shift function ?
biggjimm
Tony I've got the exact same setup except mine is a 90 model & I've ran this boat for about 10 years assuming there was no provision for the warm up like I was accustomed to on the various merc controls I've had over the years so I always just set at the dock & let it run for a while & a couple lakes I fish are no wake & the plugs always get fouled real bad if I idle it around for a long time & I always say if this stupid control had a warm up function & lo & behold you post this question that I never even thought to ask & jakedaawg comes along & saves the day. I never thought to try pulling the shifter away from the box but that's exactly how it works .This site & these guys on here are amazing. These guys really know their stuff when it comes to these boats. I'm glad I found this place, it has saved me a few times now &now I have a warm up function on my boat!!! I'm ready to take it to the water right now & try it out. Thanks again guys. Jim.
biggjimm
Hey Tony, I know this is off topic of your original post but I have yet to find anyone with the same set up I have & I was wondering if you could tell me a few things about your boat.
How fast will it run at wide open & at what rpm does it run at wide open? Some of the guys on here said 6000 rpm which is about what I thought it should be but I don't think I'm getting anywhere close to that.
Also do you know what prop you run? Mine is 13.25 x 17 but it has been changed & I don't know if that's yhe correct size for it or not . Thank you very much! Jim.
Tony T.
Hey Jim I can't give you much info because I just bought this boat and motor a little over a week ago and have not had it out on the water yet. I did get the original owners manual with it and I believe it said the the 60/70 hp was rated at 5000-6000 rpm at full throttle operating range. It's showing 60hp motor at 5500 rpm at the propeller. I have not had the prop off yet to find any marking for dia/pitch didn't find and marking on the outside of the prop to indicate. When I do take it out I'm going to compare the speedometer to my gps to see how fast it'll run with two people and gear.
Here's a couple pics of the boat
Tony
Tony T.
No Title
biggjimm
Looks just like mine except blue stripes on side are red on mine. My prop is marked on the inner hub right around where the nut is that holds it on. It had some crud on it but once I wiped it off it was there. Of course yours could be different. Mine runs 25 mph on the dash gauge (have not had GPS with me yet) with just me & 6 gal of gas & no gear. I would have thought that 60 to push it a bit faster than that but maybe not. When you do run it if you could share that info with me it would be great. Either on this posting or you can pm me. Thanks Tony & good luck with your new boat! I love mine (especially now that it has a warm up function. Ha) thanks. Jim.
Tony T.
Thanks jakedaawg and racerone for the info that really helped out alot.
Tony
